Low voltage at low revs
Jamie
Post by Jamie »
Just replaced my alternator on R50 Terrano with brand new item. Not genuine however. Dash lights and heaters dip in power when at idle. Voltage returns as revs lift. What is the problem here?
kbushnz
Re: Low voltage at low revs
Post by kbushnz »
Dud alternator...
Mattman
Post by Mattman »
Bust out your multi meter and check the voltage and idle. As above possibly a dud. Rather than getting a repo you are often better off rebuilding your existing alternator.
Matt.
evolution02
Post by evolution02 »
Probably normal, need to get a volt meter and check voltages
Alternator output depends on engine revs. So wont have much output at idle and with the lights and heater voltage will go down.
You need to check with a volt meter.
slidenyo
Post by slidenyo »
are all the wires hooked to the same spots,
some alternators need a signal wire to let them know when to start charging/regulating to 12volt
ChurchurDan
Post by ChurchurDan »
Check it with the engine warm. The after glow on these stays on for a while when first started and really draws some power. When warm the voltage should be 14-14.5 at about 1000 rpm with every thing turned on, if it cant do that its a dud.
