Another project
muddyplumber
- Spring Free
Another project
This has found its way into the garage...new project.
Re: Another project
Sweet, looks like fun. What's hiding under the bonnet? hope those holes werent cut for anything less than a turbo hanging off each side of a V8?
- Chairmen
Re: Another project
What a beast! So whats your plans for the weapon ?
muddyplumber
- Spring Free
Re: Another project
Has a worked 1kzte under there with mechanical pump, hydro bump stops,line lock set up,holes are cut for coil over towers, just in process of getting 14" ones,currently changing afew things to get it to si lower as its been built to run 40z.
Re: Another project
would love to see this tearing up once its done!!!!
muddyplumber
- Spring Free
muddyplumber
- Spring Free
muddyplumber
- Spring Free
Re: Another project
New welder has arrived, time to make coilovers fit now
muddyplumber
- Spring Free
Re: Another project
Progress has been slow, busy at work.Have almost finished fitting coilovers, will post up some pics soon.Have gone with 16" 2.5" Fox coilovers with external resiovour. Still to finish...
-drive shafts
-drive shaft loop
-finish fiddle brakes
-exhaust
-rear mount radiator
-bars and winch
-drive shafts
-drive shaft loop
-exhaust
-bars and winch
muddyplumber
- Spring Free
muddyplumber
- Spring Free
