Best battery to fit in standard vit tray?
For all Suzuki related topics
crzyfl
Post by crzyfl »
Need bigger battery with more cca for winch etc.
What are you guys running?
Or should I forget it and put the battery in the other side with a new tray and change the wiring loom to reach?
DISCLAIMER
lincooln
Re: Best battery to fit in standard vit tray?
Post by lincooln »
I would do a double battery setup, one big one in the boot and the standard one where it is normally.
Also if you haven't already, upgrade your alternator to help with the load and recharging.
I started to head down this route just before I sold my zuk.
Lubrication Specialist
Lubrication Engineers
williamhamilton
Post by williamhamilton »
crzyfl wrote:Need bigger battery with more cca for winch etc.
I did this.. http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=36181
Where in the country are you?
W
crzyfl
Post by crzyfl »
Ohakune,
What battery is that? Mine is an 8v, so battery is on other side, although it will need relocated eventually anyway.
DISCLAIMER
williamhamilton
crzyfl wrote:Ohakune,
Neuton Power Spiral Battery. Found it bloody good little package for the price.
http://www.yhipower.co.nz/brands/neuton-power/neuton-power-spiral-batteries
W
Return to “Suzuki”
