I was overseas for a month and forgot to disconnect Safari battery cables (24 volts, twin battery system) before leaving. When I got back and tried to start the car it was completely dead, no interior light, clock, nothing.
Hooked up a charger which refused to start charging so I picked up a multimeter and checked voltage on each battery.
Right one (negative on ground) was down to 9 volts, left one (negative on other battery's positive) had -3.4 volts
First time ever I've seen battery polarity to reverse. Managed to get it back to life by first completely draining it out with a bulb and wires. Then disconnected all battery leads and hooked both batteries together with jumper cables connecting + to + and - to -
After that I left it to trickle charger overnight and now it's going just fine.
Must have been that connected leads drained the left battery completely and then positive voltage from right battery caused polarity to change.
