alternator
brakes-shocks-lockers-etc
mud_slinger
alternator
Post by mud_slinger »
how can i stop crap gettin into my alt? the last 2 times i been out it has stopped chargin and pullin it out after each trip is jus plain annoyin!! anyone have any ideas? cheers
logger2
Post by logger2 »
I have never had a problem with my alt it seems to work fine after it drys ? I have had it in swamps with the dash lights on but when I come out it clears pretty quick ??
How much crap are u puttin through yours?
mud_slinger
not much at all like mud holes and that but nothin more. i replaced the brushes last week cos they were naffed and it seems to jus hold 12 volts wont go any higher. i blasted it wit hose but nothin. i dont get it
Is there a shroud or guard or something missing thats allowing excess mud and crap to be caught by the Alt?
mud_slinger
im not sure, its in a dumb place. pretty sure no missin shrouds or anythin but i could be wrong?
rokhound
Post by rokhound »
You need to have it up as high as you can.
With the 6m conversion in mine, the alternator was down real low, so I made up some new brackets etc and swapped the position that it sat in with the p/steer pump.
I also kept the std Hilux alternator with a remote regulator, which is mounted well up and back in the engine bay.
mud_slinger
yea i was wantin to move it up in place of my air con pump but not sure how to.... voltage regulator????
A chev conversion might be the easy fix to your problem :oops:
mud_slinger
ha if only... til i can arrord it i'll stick to my dirty desiel
albundy
Rolly Polly
Post by albundy »
I have the same problem, have become an expert in reconditioning them now. I just religiously pull it down and clean every six months and replace the brushes. plus I carry a spare one and can swap one in under 1/2 an hour now. You may need to replace diode.
Al
Moriarty
Post by Moriarty »
rokhound wrote:You need to have it up as high as you can.
Good idea, Rocky, I am gonna have to do that too. Bloody ALT is way down near the bottom pulley, DUMB ass place to put it.
Stupid me, I never thought of actually MOVING it!!! SS not the only dumbass......
mud_slinger
i no some dumb ass put mine by bottom pulley too it stupid. i only replaced brushes last week and was fine til i hit the mud on sun
mud_slinger
jus found alternator issue, wasnt alt at all, was the chargin relayn in fuse box
niblik
Post by niblik »
glad to see ya sorted the 'alternator :wink: ' issue slinger..
a fuse aye? sweet... better that than the expensive version.. :thumleft:
mud_slinger
yea now jus gotta go get my clutch and put it in and i'll be sorted. hopefully anyway. :roll:
