I'm back,after a long time away and sad but costly crash (don't ask) I may be acquiring a bj70 sounds pretty stock 2 inch lift 35s and boost wound up a tiny bit 270kms, has a problem or two tho
First problem steering damper is f**kd ,
Second is the leafs could do with a reset,
Third shocks are fucked
Fourth open diffs
In short has cert re on hold and wof what is it worth it's a 1985 with some good points
35 15x10 creepy crawlies beedlocks
Custom bar work
Ac has been turnd into a compresser with a tank in the rear.
In
Short whats it worth
