over heating
basics
over heating
Post by basics »
96 disco v8
went around redrocks on the weekend, coming through the sand i noticed it was getting hot. engine started steaming ect. I let it cool right down added more coolant and off we went, did this twice on the way in. was fine on the way out.
today when climbing a large hill, 2000rpm slow speed so no cool air going through the radiator again it got hot.
im gona flush the rad this weekend, but i didnt notice any sludge when the water was boiling out. so if its not a build up of sludge causing this, could this be a water pump issue?
thanks
(yes skid, i know i should get Toyota again :x )
99 pajero exceed 3.2
Ralfie
Re: over heating
Post by Ralfie »
Radiators have a habit of blocking up over the years.
Pull radiator out and get it professionally checked for flow.
Had similar to a RR a while back and it was all down to radiator. Recore or cheaper aftermarket replacement and all was good again.
DieselBoy
Re: over heating
Post by DieselBoy »
Viscous fan.
slidenyo
Re: over heating
Post by slidenyo »
radiator blocked?
viscous fan shagged?
waterpump impeller rooted?
thermostat f##ked?
frostplug leaking?
steel core rubberwear rusty and blocking rad core?
these are what i'd work through whilst giving it all an overhaul,
a compression check is also very telling if a bit of air is leaking into to the water gallerys past the head gaskets,
addition of waterwetter and a quality glycol/inhibitor helps also.
I have done some cheap fixes with a dishwasher cube cooling system flush
and replacing hoses to get me home from up north (whangarei to Hamilton)
noexitroad
Re: over heating
Post by noexitroad »
i'll put a fiver on the radiator.
recoring is expensive, and there is a cheap way and non-cheap way so if getting quotes make sure you are comparing apples with apples
Jono51
Re: over heating
Post by Jono51 »
also check the heater core
UBZ
Re: over heating
Post by UBZ »
DieselBoy wrote:Viscous fan.
x2
So it's fine untill you put the engine under load at low speed ie low air flow .?
go for a slow drive up a hill when it gets hot , pop the bonnet and see if you can spin the viscous fan by hand . of you can its rooted .
basics
Re: over heating
Post by basics »
ok, cheers for all the tips guys, looks like ill be busy on saturday.
im hoping its a non expensive fix :roll:
Ralfie
Re: over heating
Post by Ralfie »
Any update for this?
basics
Re: over heating
Post by basics »
i havnt had a chance yet to have a look, i gona flush it first and see if any improvment.
Mudde1
Re: over heating
Post by Mudde1 »
When the motor get hot, put your hand on the radiator core to see if it is hot as well. if it is cold it is likely that the thermostat is jammed closed. If the radiator is hot in patches and cold in patches the radiator is partly blocked.
Tony
Tony.
basics
Re: over heating
Post by basics »
Mudde1 wrote:When the motor get hot, put your hand on the radiator core to see if it is hot as well. if it is cold it is likely that the thermostat is jammed closed. If the radiator is hot in patches and cold in patches the radiator is partly blocked.
Tony
this is all good advice. ill keep it in mind. ill have to find a steep hill to get her hot so i can try this :lol:
thanks tony
noexitroad
Re: over heating
shouldn't be hard in wellywood?
BlakeNZ
Re: over heating
Post by BlakeNZ »
the radiator can be one third blocked (all down the bottom by the way) and you can't tell from looking.
That fan and the radiator core are ranked first and 2nd by me, then the thermostat.
Cameron
Re: over heating
Post by Cameron »
be wary that, a blocked/partially blocked radiator will also stop the fan getting enough heat passing over it to lock up.
slidenyo
Re: over heating
Post by slidenyo »
bang, that is the best piece of advice I've heard in ages,
theory of it is so simple but I've blind eyed that little gem heaps of times
basics
Re: over heating
Post by basics »
Cameron wrote:be wary that, a blocked/partially blocked radiator will also stop the fan getting enough heat passing over it to lock up.
sorry, this means what :?: :oops:
ive got this saturday free, so ill be pulling it apart if the weather holds out
