g13a head on g16a
Posted: Wed Aug 07, 2013 5:59 pm
by jervisad
i have heard that if you put the 1300 head on the 1600 that it makes it go better because of higher compression in the 1300? is this true? just wondering cause i have a couple of 1300s sitting at home. only asking cause i couldnt find much in the forums
Re: g13a head on g16a
Posted: Wed Aug 07, 2013 6:22 pm
by Heath
Smaller valves so I would imagine it would struggle to breathe efficiently.
Posted: Wed Aug 07, 2013 6:27 pm
by jervisad
yeah thats what i thought as well ae but yeah thought i would ask you guys
Posted: Thu Aug 08, 2013 10:20 am
by zukmeista
Yeah not a good idea the ports are smaller as well. As for the compression ratio, it would be the same. There are two variants of G13 in SJs/Samurais, the first is the G13A which is 1328cc and has a compression ratio of 8.9:1. The second is the G13BA which is 1298cc and has a compression ratio of 9.5:1 (same as G16A) The reason for the difference is that the G13A has dished pistons and the G13BA has flat-top pistons. The heads are the same so neither will increase the compression ratio of a G16A.
Posted: Sun Aug 11, 2013 1:44 pm
by jervisad
ohk sweet as mate cheers for all the info
