Page 1 of 2
10th-11th of august
Posted: Fri Aug 09, 2013 2:34 pm
by Crash bandicoot
I have a three day weekend so I'll kick this one off.
bought a 80 channel GME TX3100 prs with antenna of trademe and fitted it in the truck.
ripped out the poxy the drink holder(that wasn't big enough for a large macca's cup anyway) and trimmed up the dash to fit it in.
Since the suspension lift and roof racks it doesn't fit in under ground carparks i decided to mount the antenna on the roof rack as it unscrews from the lower portion of the flexi mount.
tested the A/C pump- on board air conversion for leaks. It charged up to 120 psi nicely so should be enough to bead a tire if required
Re: 10th-11th of august
Posted: Fri Aug 09, 2013 4:10 pm
by Cameron
nice install!
Posted: Fri Aug 09, 2013 8:26 pm
by coxsy
New drive shaft to be installed in the rear of the safari tomorrow new spring bolt for the fj40 so ready for our trip to see the 50 year old DC'3 crash site on sunday
Posted: Fri Aug 09, 2013 8:32 pm
by Mattman
Crash bandicoot wrote:Tested the A/C pump- on board air conversion for leaks. It charged up to 120 psi nicely so should be enough to bead a tire if required
Pics of your setup?
Posted: Fri Aug 09, 2013 8:41 pm
by Crash bandicoot
Pics of your setup?
will stick some up tomorrow arvo. with a how to.
Posted: Fri Aug 09, 2013 8:56 pm
by Cameron
coxsy wrote:New drive shaft to be installed in the rear of the safari tomorrow new spring bolt for the fj40 so ready for our trip to see the 50 year old DC'3 crash site on sunday
that the one in the kaimais? plenty of pics plz
Posted: Fri Aug 09, 2013 9:06 pm
by wopass
Friday: replaced the front window rubbers in the 80 after work.
Wooohoooo!!!!!
no more sticking windows in the cold!!!
cheers Tim (suzolla) for dropping them on my bench :mrgreen:
off to woodhill on sunday to race but on 2 wheels not 4 (dead toad hare scramble) will be my first race in about 9 years!! :shock:
Posted: Fri Aug 09, 2013 9:26 pm
by Crash bandicoot
wopass wrote:Friday: replaced the front window rubbers in the 80 after work.
Wooohoooo!!!!!
better take a can of WD40 for the joint rust :D
Posted: Sat Aug 10, 2013 8:18 am
by nivaman
Pics of the crash please.
Posted: Sat Aug 10, 2013 12:51 pm
by Crash bandicoot
Pics of your setup?
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=37169
Posted: Sat Aug 10, 2013 12:54 pm
by 3VILC
Brought a house, heres to being broke for the next 30 years :lol: At least I will have a decent space to woork on the truck now :)
I wouldn't imagine theres a lot left visable after the rain in the past couple of years, there are a few photos online and not much left when they were taken. Would be interesting to have a look tho if you don't mind the walk. Bit of rain today too so should make the drive up a bit more interesting coxsy :)
Posted: Sat Aug 10, 2013 4:13 pm
by CLUMZ1
Scored a Redarc charge equaliser from trademe for $150, worth $344 AUD currently.
http://www.redarc.com.au/products/produ ... liser_20a/
Should be sweet for all the 12v loads on the Safari.
Also laughed at some numpty going into red rocks, literally went thru the stream after the drive way and got stuck, driving a Toyota Liteace 2WD on the skinniest of skinny biscuit tahs.
He asked me to help, reversed the Safari up and when I got out he'd already hooked his $2 Repco elastic tow strap to my safety chain mount point and around his tow ball!!!, gave him a telling off and then I used a tow strap - properly.
Posted: Sat Aug 10, 2013 4:30 pm
by uptomynutsinruts
Swapped the flatdeck on my ute over to the wellside, looks 8)
Posted: Sat Aug 10, 2013 5:02 pm
by coxsy
know there's not much there.But I will know that I've seen the site
new shaft
the fj has problems
new shaft in place no noise now
Posted: Sat Aug 10, 2013 5:31 pm
by wopass
Wooohoooo!!!!!
INOX is much better :lol:
Posted: Sat Aug 10, 2013 6:43 pm
by Crash bandicoot
was gonna say coxsy , that drive shaft hoop is rather close in'it? :shock:
Posted: Sat Aug 10, 2013 6:59 pm
by muskie
Crash bandicoot wrote:was gonna say coxsy , that drive shaft hoop is rather close in'it? :shock:
and why do you have it?? was it rqd for cert???? something i hadnt considered with just a 3'' lift :?
Posted: Sat Aug 10, 2013 9:03 pm
by basics
CLUMZ1 wrote:Scored a Redarc charge equaliser from trademe for $150, worth $344 AUD currently.
done my good deed in the same spot last weekend, some guy in a 2wd rav4
the two men in the front seat had the women passangers out pushing when we found them :lol:
not even a thank you, the lazy driver didnt even get out the car to help. :roll:
Posted: Sat Aug 10, 2013 9:07 pm
by terrano
Went for a drive up the lees valley, great day up there and truck went well :D
Posted: Sat Aug 10, 2013 9:15 pm
by a80crewza
terrano wrote:Went for a drive up the lees valley, great day up there and truck went well :D
Hey terrano, which road do you turn off to get up there :?: , looks nice..
Posted: Sat Aug 10, 2013 9:24 pm
by FORGE1
Fitted 3inch lift in the safari tonight got the hd rear spings to match the ones I got off datsunsafari. Haha there is no give in the back. I can't even bounce it so hope they settle and give some movement.
Will post pics tomorrow.
Next on the list is a set of 33s.
Posted: Sat Aug 10, 2013 9:27 pm
by mack
finished the build of bullbar off and droped it to sand blasting/primer then ill throw some black over it and bolt it on oh and bought a equaliser strup
Posted: Sat Aug 10, 2013 9:52 pm
by terrano
Hey you go through oxford and turn onto ashley gorge road than head up lees valley road, it not very well sign posted i drove past it at first :lol: And just follow the road, awesome scenery
https://maps.google.co.nz/maps?q=Lees+V ... y&t=m&z=15
Posted: Sat Aug 10, 2013 9:58 pm
by a80crewza
Awsome cheers mate, might get up there tomorow :)
Posted: Sat Aug 10, 2013 10:07 pm
by coxsy
Yes for cert and no hits on it,from time I made and fitted it.turbo on engine requires a loop ,a turbo safari has same part number drive shaft
Posted: Sun Aug 11, 2013 1:11 pm
by CLUMZ1
basics wrote:done my good deed in the same spot last weekend, some guy in a 2wd rav4
haha I didn't even realise RAV's came in a 2WD model, they are honestly driven by the most useless fecktards I've seen on the road.
Posted: Sun Aug 11, 2013 1:37 pm
by brevin
Dropped the gearbox out of my LN106 yesterday after buying the new gearbox earlier this week. Unfortunately got stuck with putting the new gears onto the tail housing so have to figure that one out before it goes back in. :wink:
50% completed... hanging out to drive the old girl again.
Posted: Sun Aug 11, 2013 6:22 pm
by Weemsy
Went to costa plenty with deranged, big t, Clive, buzz, nobber and half a dozen others
Had a ball. Was as muddy as could be and never stopped raining
Made the Chevy lux work for its fuel bill :D
I'm sure pictures will be posted shortly by someone
Posted: Sun Aug 11, 2013 6:48 pm
by Xr246
Finished panel on the tub of my FJ40 on fri night and sat morn. Slapped a couple of coats of mustard yellow on
https://fbcdn-sphotos-h-a.akamaihd.net/ ... 6593_n.jpg
Underbody sealed the floor today and fitted one wheel to see what it looked it
https://fbcdn-sphotos-g-a.akamaihd.net/ ... 4164_n.jpg
Posted: Sun Aug 11, 2013 8:43 pm
by Filthy4x4
Another weekend at Possum Palace setting tracks, didn't manage to get my truck up there so ended up being winch bitch for sibainmud :mrgreen:
Got another 5 tracks sorted, its looking real good up there :twisted: :twisted:
We had 1UZRNR (Jesse) and his partner Amy, join us for the weekend also, was cool showing them how we wheel down here. Amy cooks some mean brownies too :mrgreen: :mrgreen: ... They have limited internet access, and are in the North Island for another 4-5 days then they fly to the South Island... Im know they would love to go wheeling while down country, PM me for their number and take em out for a day 8) 8)
Caleb
