Six million $ strange rover comp truck
Batfastard
Dr. Love Glove
Post by Batfastard »
Thought it was about time I posted a build thread .was going to build from scratch but did the maths and bought this. Blue range rover, for 8k. It's well set up but very untidy . F&r lockers fiddle brakes,howat axels. Banded cvs,bead locks, rear mounted rad .pto winch rear warn winch bars body lift, springs shocks mod and all reg wof and certed . Thought it would be a good place
Batfastard
Dr. Love Glove
Re: Six million $ strange rover
First job was to pull the old four point cage off and build an Exo Image
[img]http://img163.imageshack.us/img163/9303/cu4e.jpg
[/img]
It took a while to nut out the cross bracing ,so cut two holes through floor rolled some tube and welded to chassis
Then it was time to mount spare
Roof cross bracing
Time to paint
It was a mission but I'm stoked with the out come
Batfastard
Dr. Love Glove
Re: Six million $ strange rover comp truck
As we wanted to run simex 35" had to trim the front guards
Dents out and primed
As the rear of the chassis had been chopped of I had to shorten and re manufacture the rear guards it took a lot of fu&kin around to get them to look factoryish. But got there in the end .
Then rubbed it all down and top coat time . Used the same colour paint as the green taxis but left the white out of the paint and got a deeper lime green
Was a bit tricky getting rear guards behind the Exo . Had to bolt corners on after that was a mission .
Don't look at the other green convirtible rangerover I been doing that for six years . Now I can post pics I will do a build thread for that puppy
Big
Post by Big »
Mate what a transformation.. thumbs up well done.. :D
Batfastard
Dr. Love Glove
Picked up the block girdle idea I seen on the nett for a small block ford. So I re hashed it to fit a rover bottom end and got it water jet cut out. Lookin flash ,and fits.
Then splashed out.on a flash stud kit and nuts
Ford Cleveland ones fitted
Then picked up all engine stuff that got balanced
They also took 1.5kgs of the fly wheel. It's a fine line between not enough off and to much .
Now the plate is getting milled so the big end blocks fit in nice and snug
Will also be able to fit another 1.5l of oil in the sump . Now I should baffle the sump as well. More jobs less time
mazdamike
Post by mazdamike »
what gain do u get from the girdle?
Batfastard
Dr. Love Glove
mazdamike wrote:what gain do u get from the girdle?
When you give it the big squirt the block dose not twist and the crank fall out :oops: :D .thats why chev went to four bolt mains.
Batfastard
Dr. Love Glove
The front bump stops mounted . There was no room to mount them so they bump on on the diff so welded a plate on radius arm seems to work good Image
Batfastard
Dr. Love Glove
We have had a couple of bad days getting the motor back together . Starting with a big fxxk up that I have to own 12 months ago I sent the p76 heAds away to get ported . Not even I sent some rover ones away by mistake . But all good the only diffrance in one row off bolts that we don't need to use and they oil the rockers difrent p76 through lifters and hollow rods rover has oil holes in head . So we use p76 lifters and rods .
Next problem is because we got so much lift in the new cam our install height is not standard so made packers to lift rocker gear up 1.2 mm . Dial cam in which changes valve time ing and inlet valve hit the piston. Look hard and u can see indent in the playdo.
So I cut a valve stem of a valve welded it to a cutter made a hight jig . So put stem through head bolt head on and drill the piston in exact place as
valve hits. And it worked.
Do this eight times and then tidy pistons with a dia grinder. And that's how to waste a day when every day counts when u only got 15 days til t1000 start .
Big
Post by Big »
hope you don't melt a piston doing that grind so close to the edge..? otherwise mean build for a LR..lol
Batfastard
Dr. Love Glove
It's a wrap .its all together and turns over free .
Just need to make it roar now
skidmark
Post by skidmark »
looking good there! I saw it on trade me a while ago.not recognisable now!
Batfastard
Dr. Love Glove
Got the twin shocks on the front now.
New vented disks flash pads and replaced all rubber and steel hoses and lines
Swapped the steering arm for a disco one sits abut higher. Went for the upgraded arms and rods
Fitted front shocks on back so all shocks a one standard sord . Used some bolt on brackets from the uk to make it easy
Image.
Hyd bump stops and discolation cones on rear as well
Batfastard
Dr. Love Glove
Put the 31.10.5x15 tyres on that we are going to run for the t1000
Big thanks to ace 4wd in ch ch for there generous help with the rubber . The smaller wheels and the increase in hp will help us out of the corners
Now off the hoist with full weight on wheels
Tread pattern
shortylux
Post by shortylux »
Nice work. See you there!
ice4x4
Post by ice4x4 »
Very very 8)
Unfortunately I am at sea so cant come and watch :(
1988 Range Rover Classic
2010 Discovery 4 HSE 5.0 V8
Batfastard
Dr. Love Glove
Some pics of a few jobs completed last week.
One ten cable handbrake . Works mean as
I love this mod moved the vacume centre diff up onto the gear lever. As when harnessed in I can't reach it on the floor
Batfastard
Dr. Love Glove
Today went well got through a few jobs. Got the disco 2 fuel tank mounted on the rear so we now got 172 ltr of fuel
Tank in place going to mount a pump and transfer into main tank
Had to remount spare
Batfastard
Dr. Love Glove
Made up a front and rear driveshaft hoop. They need a clean up and paint
Front
This one bolts on in the same place under the diff as the steering damper. As it travels up and down with diff it will never hit the driveshaft
Rear
It bolts on to a factory bracket on the chassis
Batfastard
Dr. Love Glove
Well don't let any one tell you a p76 just bolts straight in to a rangerover first job is to mod engine mounts Image
It was one of those days . Hope today goes better
turoa
Pyro Junior
Post by turoa »
Na they don't go right in, heres a good page for a bit of infos :mrgreen: http://andic.co.nz/id22.htm
Keep up the good work, be good to see it roll over the start line 8)
shortylux
Post by shortylux »
Don't roll over at the start line. That's Telexs trick :lol:
Still, he finished the race :oops:
Batfastard
Dr. Love Glove
Another very frustrating day
Finished painted engine mount
Empty hole
Ready to go into empty hole
The return pipe from rear radiator fouls on the extractor , so will have to run that down other chassis rail. And extractor is in the way of the drive shaft for pto winch . It seems to never end . So I need a super human effort tomoz :-)
shortylux
Post by shortylux »
Good luck mate. I guess you don't need a pto for Taupo, but the radiator will be hard to live with out.
Sounds like I wont be to busy on the Friday so if you have any little jobs still to do once you arrive at the event, don't hesitate to ask.
Arron.
0272782556
Batfastard
Dr. Love Glove
shortylux wrote:Good luck mate. I guess you don't need a pto for Taupo, but the radiator will be hard to live with out.
Arron.
0272782556
Thanks for the offer
Batfastard
Dr. Love Glove
Well got the rear radiator pipe fabed up and tacked . Bolted headers on welded flanges on the headers and made exhaust
Went to but dizzy in and noticed that it was not free . Pulled it apart weights were rusty as . So free up . Slipped into the hole and oil pick up was different . So made a jig up so I could press gear of both shafts and swap over . Was a lot easer writing about it than doing it
Starting to get over this two steps falword and one backwards. I wonder what Friday will have installed for me
willie
Driving Ms Daisy
Post by willie »
Nice looking truck its taken a turn dude and loos f**ken cool now,
look forward to seeing it in action. :D
When I die, I want to go peacefully like my grandfather did — in his sleep. Not yelling and screaming like the passengers in his car.
Batfastard
Dr. Love Glove
Well it roars ,what a transformation.ran the cam in and then took it easy for 15 mins then drove it like i stole it...but only rev it to 5000 :D .have. Not loaded it up and given it death .but it rocks now.
105 kph in second 155 kph in third and it was only a short straight.so it was into forth and then brake but i ran out of speedo 8) and the stop sign was getting real close.
Its a real hand full in second gear in the drive way at mamuku 4wd
With the rear shocks being oposing rather than being side by side has taken care of the body roll .and the caster corecting mod gives mint steering one handed at 180kph
The money spent on the brakes was money well spent.
Was a very happy camper .had a wtf moment at 180 the winch was in free spool and there a bang and a very matalic rattle me first thought was a rod out the side ,but it was my winch rope and hook bashing the under. Side of truck .how luck was i that it did not pick up one of the drive shafts.
So today was all electrics.wire and shit .
We used the rover injection and computer not time to sort link out .but fitted a air fuel digital gauge it di not seem to lean over 150 kph but will just drive to the gauge .although it goes real well its like a v8 with a two barrel carb .
Exhaust is real loud but sounds mean two and a half to the y and then three " no muffler any one got any ideas on a muffler ....
niblik
Post by niblik »
Mean.....
Smurf
Post by Smurf »
Sounds like there is a happy Range Rover owner, Sounds like an impressive machine.
