LD28 Water pump Help!
For all Nissan related topics
nakimud
Post by nakimud »
S3 landy with LD28, water pump has bitten the dust, does anyone know where to get a new one? If you can get them? aren't the petrol ones different? thanks heaps
Crash bandicoot
Re: LD28 Water pump Help!
Post by Crash bandicoot »
http://nissan4u.com/parts/laurel/el_c32/1986_2/type_16/exhaust_and_cooling/water_pump_cooling_fan_thermostat_water_hose_and_piping/
here's ya part number Should be the same for all LD28's regardless of what vehicle they went into.
part master/ supercheap ripco appco the local garage where ever
nakimud
Post by nakimud »
thanks crash, there is two bloody part numbers on there though, with no differentiation between them
Crash bandicoot
nakimud wrote:thanks crash, there is two bloody part numbers on there though, with no differentiation between them
go with the one that just says water pump. as the other one is a kit with the pulley etc.
Crash bandicoot
may be also cheap er to ring forklift servicing agent as the nissan medium duty forklifts runs LD28's
