'Tuff Lux's LN106 4 link
ln100matt
Post by ln100matt »
Been doing a bit of work on my mates ln106 double cab hilux. Half way through a double triangulated four link so I thought I'd put some photos up.
Some mods we've done so far are:
- Stock 1uz
- R151 with gear driven transfer adapted
- Rears up front with crossover steering
- Longfeilds
- Rear lokka and lsd up front
Before
Crossmember for lower links
Finding out height of spring with weight on
imsohi
Re: 'Tuff Lux's LN106 4 link
Post by imsohi »
looking 8) mate
ln100matt
Post by ln100matt »
Got a bit more done. Everything welded up. Just need to mount fuel tank then flex it up to get shock lengths then paint everything. Can anyone suggest a good paint to use?
Cheers, Matt
Crossmember all welded up
Diff welded up
Crossmember in
Springs mounted
willie
Driving Ms Daisy
Post by willie »
Looks good top effort cant wait to see it completed 8)
When I die, I want to go peacefully like my grandfather did — in his sleep. Not yelling and screaming like the passengers in his car.
nizute
Post by nizute »
If you can paint from a gun i would recommend a good etch primer and 2pack enamel.
ln100matt
Post by ln100matt »
Got it pretty much finished now. Still a few bits and pieces to tidy up but got it up the bank for a flex up. Could of got a bit more out of it but the tray sits on the tyres so might need to mod it a bit.
tomsoffroad
Flopsie
Post by tomsoffroad »
Nice 8)
wopass
Post by wopass »
Ohh it's good to see that you know what I mean, it's bloody Shit hot seeing that come together just shit hot you know what I mean.
:mrgreen:
Mattrade
Post by Mattrade »
Nice flex, well done 8)
tuff lux
Post by tuff lux »
Went for first run on suspension just a few pics.. Really impressed with it
Still hitting tray
Still hitting tray
marmite89
Post by marmite89 »
Hey mate obviously the triangulated 4 link is fully custom so how do go about lengths and where mounts need to go? I'm doing some homework on how set one up on my surf.
ln100matt
Post by ln100matt »
marmite89 wrote:Hey mate obviously the triangulated 4 link is fully custom so how do go about lengths and where mounts need to go? I'm doing some homework on how set one up on my surf.
I downloaded a 4 link calculator to help with dimensions which was a good starting point for me as I hadn't done one before. I researched antisquat, roll centre height and angle, etc and what some good figures for these should be and based the design around these. At the end of the day though, what works on paper might not work under the truck so I didn't get too carried away with making it to exactly what the calculator gave me. In the end the truck behaves quite well and pinion angle is good throughout the length of travel.
marmite89
Post by marmite89 »
How did u get your crossmember? Do u have to measure it up yourself do can u buy them made up and add your mounts?
ln100matt
Post by ln100matt »
Na made it all myself. Trailgear in the states sell a similar setup
