DONT LAUGH!!!!!!!!!!!!! Disco Tune
Posted: Wed Aug 21, 2013 8:22 am
by Disco Gofer
I have a 94 Disco TDi 200 auto. I only use it for the odd fund raiser Safari or for towing my V8 bush truck into Ngaroma when I want to camp in it as I normaly use my Ford Ranger.
Just wondering if there is a bit of tweeking I can do to give a tad more grunt other than fitting a Lexus V8................
I already fitted a 1000 amp battery, 100w light bulbs, spots AND a winch for the up hills but nothing worked...................
Re: DONT LAUGH!!!!!!!!!!!!! Disco Tune
Posted: Wed Aug 21, 2013 9:28 am
by DieselBoy
Injector pump is very easy to adjust for more smoke and power :D :D
Google is your friend :mrgreen: :mrgreen:
Posted: Wed Aug 21, 2013 1:12 pm
by Disco Gofer
More smoke........and power. Im ok with more smoke giving more power. It doesnt smoke at all now unless i tow with my foot down hard so will do some checks and see how far I can go.
Posted: Wed Aug 21, 2013 1:13 pm
by Disco Gofer
It is worht me fitting EGT gauge? Cant harm it?
Posted: Wed Aug 21, 2013 4:38 pm
by zukmeista
Definitely do that before playing with the fuel, will tell you when your motor's getting too hot so you can back off before it melts a piston.
Posted: Thu Aug 22, 2013 8:31 am
by Disco Gofer
zukmeista wrote:Definitely do that before playing with the fuel, will tell you when your motor's getting too hot so you can back off before it melts a piston.
Getting one today thanks!!
Posted: Thu Aug 22, 2013 9:59 pm
by Darby
I had a Disco and I was running at max free boost 25 psi in it and all I did was disconect the wastgate, advance the fuel injection and put a intercooler that went from one slam panel to the other. I had a piro and a boost gauge and watching them when I was pulling 2 1/2 tons up a steep it only got to 25 psi free boosting with the standad turbo so its not putting any real stress on the motor.
Posted: Thu Aug 22, 2013 10:10 pm
by Mattman
25psi!
Posted: Thu Aug 22, 2013 11:04 pm
by Darby
Yea the wastgate is set for 16 psi from factory so its not that much more .
Posted: Thu Aug 22, 2013 11:29 pm
by DieselBoy
Mattman wrote:25psi!
Yup, the little Garret's crank out 25psi easy, but just create heat and loose efficiency over about 15psi which is the factory pressure.
Posted: Fri Aug 23, 2013 6:44 pm
by Darby
No they only start looseing efficiency at 20 psi and the heat that they create is taken away by the massive intercooler and so its still a good boost.
Posted: Sat Aug 24, 2013 4:48 pm
by DieselBoy
True, how did you determine its efficiency up to 20psi???
Be interested to see your calculations :D :D
Posted: Sun Aug 25, 2013 10:27 pm
by Darby
To tell you the truth I didn't do any real calculations.
I ran 2 piros one before the turbo and one after a boost gauge a vauum gauge before the turbo, inline oil and water temp sender and my mate made a sencer unit to get the speed of the turbine but no real calculations.
How how did you determine that it was 15 psi?
Posted: Sun Aug 25, 2013 10:37 pm
by Mehrts
Just out of interest, what sort of RPMs was the turbo getting up to?
Posted: Mon Aug 26, 2013 11:35 pm
by Darby
Mehrts wrote:Just out of interest, what sort of RPMs was the turbo getting up to?
The top RPMs i saw was 34,000* at 25psi.
http://www.turbobygarrett.com/turbobygarrett/sites/default/files/accessories/781328_Speed_Sensor_Kit_Installation_Instructions.pdf
(*thats a rough number from memery)
