Bit Of Advice.....
For all Nissan related topics
BogBoy
Bit Of Advice.....
Post by BogBoy »
Ok so I was jacking my 4wd up yesterday using the factory towing hook.
It dropped a bit but held. I thought it had bent the hook :lol:
Got home and put it up on the ramps today to find out its bent the cross member and chassis end due to rust on the inside :cry:
Any ideas?
My plan was to chop it all off and replace with some box section as this would be stronger than factory and can also mount proper towing hooks on it.
Mattman
Re: Bit Of Advice.....
Post by Mattman »
What sort of truck? Front or rear?
BogBoy
Post by BogBoy »
Sorry
1992 D21 Terrano, Drivers side front.
I can try to take a picture of it if that helps?
nizute
Post by nizute »
If you know any panelbeaters,get them to do the job so you have a paper record if you ever get pinged on it for a wof, or tack the box section in and get a certified welded to finish it.
BogBoy
Post by BogBoy »
Got a metal bar in there and bent it back straight then welded it back together so it can be sent to get done right
Its the bit right above the drivers side towing hook
