91 Mu with ceased engine lockers, 33" tyres etc
Selling or wanted vehicles.
octanepwr
Post by octanepwr »
Selling my Mu, ceased engine. $1500 without wheels, in Wellington. Obviously you would need to bring wheels if you do not want to buy mine.
Wheels/tyres $700. 5x 33" hankook muds 5mm tread (spare 7-8mm), 8inch white spoke steel rims (-19 offset) great condition.
Also have 33" silverstones on 8 inch white steel rims (-19 offset), 10-11mm tread centre, look not far off new. $1100
ALL with TUBES (except the spare may not be - I bought this seperately)
0212340628
lewistoman@gmail.com
Email / call me if you are serious and want some photos.
Lewis
Ran bloody well until one day cruising along at 80kph the engine started a ticking noise, followed by a knocking noise. I pulled over put the clutch in and it died and never started again – engine seized. Never overheated, no water in oil or oil in water and no holes in the block. Oil level is normal.
This truck surprised people where it could go with the Silverstones on and the lockers. Might make a good culprit for a 3.8 v6 conversion (seen this done before).
Specs below
1991 2.8TDI
Manual
110km
WOF expires October 2013
Diesel miles 700km remaining
Rego until October 2013
2” body lift
2” suspension lift
Rear air locker, switch on gear stick
Front auto locker
2.5” exhaust
Onboard air for air locker and air tank to pump tyres etc, using aircon pump
Isuzu Intercooler and WRX bonnet scoop
Electric fan on intercooler and radiator
GFB boost tap
Aftermarket gauges – boost gauge, water temp gauge, exhaust temp gauge
EGR removed
Recently installed speakers, headunit takes mp3 player/phone/usb input and radio
Rated tow hooks front and rear, with steel bulbar at rear and tow bar attachment
Snorkel and foam air filter
Removed carpet inside
Dents as to be expected with a proper 4wd
Replaced all joints in front steering (May 2013) $500 (parts alone cost)
Mattman
Re: 91 Mu with ceased engine lockers, 33" tyres etc
Post by Mattman »
If you are interested in splitting it I would be interested in the riffs.
Matt
slidenyo
Post by slidenyo »
oh yeah sweet riffs...
Mattman
Post by Mattman »
Lol. Spliffs riffs diffs!
