what are the old toyota 2.4Diesel like on fuel
philip121
Post by philip121 »
what say a old 1990 hilux surf 2.4d be like on gas
turbo
tomsoffroad
Flopsie
Re: what are the old toyota 2.4Diesel like on fuel
Post by tomsoffroad »
Not bad then it'll blow up :roll:
Smurf
Post by Smurf »
I find it uses as much diesel as I put in the tank
muddy
Post by muddy »
2L + turbo free-boosting and fuel screw as far as it will go - used about 12 litres for the Hanmer winch challenge. (plus a couple of litres of engine oil)
lax2wlg
Post by lax2wlg »
philip121 wrote:what say a old 1990 hilux surf 2.4d be like on gas
turbo
On gas? Pretty messy if you tried to run it on gasoline Phil.
Clint
Post by Clint »
The 2L-TE in my LJ71 used to do about 12L/100km before it got biffed in favour of the Lexus V8. I didn't think that was too bad given how aerodynamic a Landcruiser 70 isn't.
But like Tom says, savings on fuel will possibly be wiped out by regular replacement of cracked cylinder heads :lol:
Clint
UZJ71 Landcruiser
KTM 640
tweake
Post by tweake »
10l/100km if driven nicely and its a good one.
add in 4x4 tires/gear and its worse.
however these are old engines and unless its been rebuilt its going to be tired.
also they are a small low powered engine in a 2 ton 4x4 with aerodynamics of a brick. very easy for fuel economy to go straight out the window.
then theres the crack easy heads, assuming its even got an original still on it.
The WEHI
Post by The WEHI »
mine used more oil then diesel lol
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
mylux
Shockless
Post by mylux »
Is it an outo or a manwell ?
tweake
Post by tweake »
add more for an auto ....and add in more overheating problems!
sibainmud
Post by sibainmud »
mylux wrote:Is it an outo or a manwell ?
Where's that f'n like button :lol:
It will use as much fuel as the troll behind the wheel lets it :!:
Be gone!
