what are the old toyota 2.4Diesel like on fuel
Posted: Mon Aug 26, 2013 11:25 pm
by philip121
what say a old 1990 hilux surf 2.4d be like on gas
turbo
Re: what are the old toyota 2.4Diesel like on fuel
Posted: Tue Aug 27, 2013 7:49 am
by tomsoffroad
Not bad then it'll blow up
Posted: Tue Aug 27, 2013 8:14 am
by Smurf
I find it uses as much diesel as I put in the tank
Posted: Tue Aug 27, 2013 9:03 am
by muddy
2L + turbo free-boosting and fuel screw as far as it will go - used about 12 litres for the Hanmer winch challenge. (plus a couple of litres of engine oil)
Posted: Tue Aug 27, 2013 11:02 am
by lax2wlg
philip121 wrote:what say a old 1990 hilux surf 2.4d be like on gas
turbo
On gas? Pretty messy if you tried to run it on gasoline Phil.
Posted: Tue Aug 27, 2013 1:23 pm
by Clint
The 2L-TE in my LJ71 used to do about 12L/100km before it got biffed in favour of the Lexus V8. I didn't think that was too bad given how aerodynamic a Landcruiser 70 isn't.
But like Tom says, savings on fuel will possibly be wiped out by regular replacement of cracked cylinder heads
Clint
Posted: Tue Aug 27, 2013 6:14 pm
by tweake
10l/100km if driven nicely and its a good one.
add in 4x4 tires/gear and its worse.
however these are old engines and unless its been rebuilt its going to be tired.
also they are a small low powered engine in a 2 ton 4x4 with aerodynamics of a brick. very easy for fuel economy to go straight out the window.
then theres the crack easy heads, assuming its even got an original still on it.
Posted: Tue Aug 27, 2013 6:57 pm
by The WEHI
mine used more oil then diesel lol
Posted: Tue Aug 27, 2013 7:57 pm
by mylux
Is it an outo or a manwell ?
Posted: Tue Aug 27, 2013 8:09 pm
by tweake
add more for an auto ....and add in more overheating problems!
Posted: Tue Aug 27, 2013 8:16 pm
by sibainmud
mylux wrote:Is it an outo or a manwell ?
Where's that f'n like button
It will use as much fuel as the troll behind the wheel lets it
Be gone!
