Wanted.
Re: Wanted.
Like the seal by your wheel bearing? That and the circlip should be just under $10 total new
Re: Wanted.
The seals are under $20 from suzuki and the circlips are a couple of dollars from an auto shop.
If it's your right hand side front cv, have a read of this!
http://www.suzuki-forums.com/1g-1999-2005-vitara-grand-vitara/37371-front-dif-loose-drive-shaft.html
The fix works well. Nylon bush is around $120 from Suzuki in NZ.
Re: Wanted.
Thanks. I've got one of those and putting it in. It's my first destroyed cv, but I'm not surprised since the vehicle was about to roll and perched on that wheel plus the diff was locked. After experiencing it, I'm definitely doing the stub axle mod next time.
DISCLAIMER
Re: Wanted.
http://www.auszookers.com/forum/viewtop ... =17&t=6953 hopefully that will take you straight there but its in their gd tec / bulletproof diff stuff seems someone over there has started making a bush for around $90. Hopefully no ones upset about another forum link
Re: Wanted.
OEM ones look much better quality than the cast urethane ones and worth the $20 difference in my opinion.
No worries about the info, hope it helps.
