kzj78 hub questions.
Posted: Sun Sep 01, 2013 11:05 am
by jonossiksilvia
Hi all.
Im currently rebuilding my hubs, swivels etc. i have tried searching but cant find the info im after (maybe wrong words being used
Anyway im wanting to know if i can replace the power locking rings with normal nut set up? im running factory hubs that are now manual engagement.
the annoying issue is every time i have to undo the t20 screws i snap my t20 bits trying to undo them - even when they are set at right torque.
If it isnt possible to add the second nut then is there an alternative solution instead of t20 screws others have used?
Second issue:
Ive brought a terrain tamer rebuild kit and it didnt include the outter seal (circled in red in following pic). i know the tt kits suit the aussie trucks. is this still needed as im not running the electric engagement side now as, as far as i can tell its only need for that?
Cheers john
Re: kzj78 hub questions.
Posted: Sun Sep 01, 2013 11:49 am
by oldblue
The red seal is only fitted to Electric hubs to stop grease from entering the carbon, so no problems leaving it out. You can buy this seal from Toyota.
2; These screws do not need to be very tight, and you could apply some grease to the CSK part of the screw.
or you can buy some Allan head CSK machine screws and alter the taper ( CSK )from 90deg to 60deg.or do the same to Cap screws.
The problem is that the key tab on electric type nuts is on the outer nut, and the key tab on none electric type is on the inner washer so I would try and stick with the electric type nuts.
Posted: Sun Sep 01, 2013 11:55 am
by kbushnz
I have a similar setup but ditched the torx bits and use ordinary phillips head screws. They don't need to be tight or locked in with thread lock..
All they do is hold the locking ring / brush slip ring in place
You can go and use the older twin nut and tab washer way but IMHO its a step back and they always seem to back off....
Mine have been like that for over 10 years now and no troubles pulling them down for a service...
Posted: Sun Sep 01, 2013 1:10 pm
by Jerry
You can use the locking ring if you dremel down the top of the spindle ... have you tried new screws only $2 each from toyota ... try a bit of copper coat on the threads as well
Posted: Sun Sep 01, 2013 3:36 pm
by oldblue
Invest in a good Tork driver bit not the cheap stuff, they always snap off.
Posted: Sun Sep 01, 2013 6:30 pm
by jonossiksilvia
hi guys.
cheers for all the replies.
1) i wont bother getting and fitting that outer seal.
2) ill use the standard setup using the power locking ring, get new screws and on just nip them up with copper coat and see if that helps for next time.
Torx bits i was using were decent quality ones too as we use them for work just with pan head screws instead
Posted: Sun Sep 01, 2013 6:36 pm
by tallsam66
Posted: Mon Sep 02, 2013 8:41 am
by wjw
kbushnz wrote:I have a similar setup but ditched the torx bits and use ordinary phillips head screws. They don't need to be tight or locked in with thread lock..
I agree, With the twin nut and tab washer they need adjusting every WOF, didn't happen with the prado
Posted: Mon Sep 02, 2013 10:27 am
by suzolla
Posted: Mon Sep 02, 2013 11:18 am
by wjw
I would be...
Posted: Tue Sep 17, 2013 6:41 pm
by Danjr
I'd be interested
