i just had me rear right hand side wheel bearing collapse on me 1990 daihatsu rocky rather pissed off. whats the easyist way to replace it and any1 know where i can get cheap bearings from? the diahatsu parts dealer down here in dunners quoted me
bearing $177 +gst !!!!!!
2 seals $20 +gst each!!!!!!!!!!!!!!
yeh we do come to think of it how much you reken it will cost. i good at twisting places like that arms been doin it for the last couple of years. the surf i bought i got the guy dow from 400 to 250 by twisting his arm and telling him sum factional bullshit (means it was true but completly irrelevent)........mmmmm beer.......
i was trying to get the bearings out of one dwn here in dunners but the guy wont sell them to me he's got sum issues a think. he wouldn't even sell me a wreaked but running truck to turn into an offroader. where as all the other places would have done so if they'd had something suitable there.
rear right hand side bearing and possibly other diff parts once i've got into it and seen what else is wrong with it.
the seals on it if they go around the bearing would/will they allow diff oil to leak out or is there another seal nearer to the diff head that stops the oil from getting down as far as the bearing?
that would be good cheers. the diffs are they same as the ones as what are in the ferozas/jap import rocky's? i may possibly need the whole axle wont no for a few days until i get the time to pull them off and have a look as to what is needed.
i think the diffs on mine might be steel they've had a few run ins with the volcanic rocks on the tracks we got round dunedin and won. they seem to have heaps of strenght. i'm going to SAS it once i've left uni an got a few $$$ be hind me also probly throw a V6 in it as well. been told i'm made doing it
Weak point is the gearbox & transfer case, found with mine mud and crap gets in the top of the diesel pump thingys (where the cable that attaches to the pedal thingy that makes it go faster when you press it) ....and it jams up amd makes it run funny, crc'ing it works for a whilst until the fan dries it, silicon spray doesn't work, am trying grease currently.....
What about a V6?, also change to eg hilux diffs as well if you are doing that as then you can get LSD's and difflocks etc.
yeh i thort that the gbox an tcase would be the weak points thats why i've formulated the plan of scrapping them and putting in new box etc aswell. just not to sure what would be good. what would fit and what a resonable price for what ever i do would be
just got me bearing fixed. had a look at it an it was F@#KED!!!!!!!!!! the outer casing had a 5mm bit missing, 2 bearings were gone, 2 were broken in half,the cage that holds them altogether was in 3 pieces, and the inner ring (bit the slips over the shaft/axle) was broken perfectly in half round the circumferance. cory in at pitstop had never seen anything like it before. thinks a bearing may have stopped rolling and wore throught it. also had to get the axle built up and machined down.
got the new bearing kit for $50 aposed to $200 from skf bearings and seals.
