Airbag spring helpers - any experiences?
brakes-shocks-lockers-etc
drive it ...
Post by drive it ... »
I've got LWB prado with about 3" lift springs that are very soft. So excellent flex when running empty but trouble starts when I jam 5 people plus climbing gear on board - back end sags out badly and its a pig on the road.
I'm using Rancho adjustables, winding up makes things a bit better but really the springs are overwhelmed by full load.
Not really keen on replacing with heavier springs.
Looking at poly air bags that sit inside the springs.
Found 1 bloke who tried them, said even with no pressure they stiffened things up too much so he pulled them out. Any one in ORE land use these - comments, thoughts?
amboguy
Re: Airbag spring helpers - any experiences?
Post by amboguy »
What about these as a alternative to polybags? don't have the problem of puncturing a bag.
http://www.waikato4x4.co.nz/Products/Sumo-Springs
oldblue
Post by oldblue »
I used them on a SWB Prado, Make sure the airbag inlet tube is at the bottom, they fit better that way.
