I have been looking into the suspension set up on my truck and I need some longer shocks.
I have done a little research into using 80series shocks on the front but dont know what I need to change to achieve this as the info is pretty limited online (unless im looking in the wrong place)
The back on the other hand needs looooong shocks as the ones in there are currently topped out (Monroe 4x4 shocks) its currently a 100mm lift in the back.
How I want the truck to sit is:
Front 75mm lift
Rear 100mm
Once I put a draw system in and load it up it should sit level
Does anyone know where I could source some 2nd hand shocks that will be long enough or a good price on some new ones.
If anyone knows small tricks that could make it work using other trucks shocks Im all ear's
Thanks in advance
