wanted : SJ prop shaft
Posted: Sun Sep 08, 2013 3:50 pm
by Big Jim
I'm after the front prop shaft from an SJ. The shaft off the gear box to the transfer case. Any helpers please?
Thanks
Re: wanted : SJ prop shaft
Posted: Sun Sep 08, 2013 4:01 pm
by BlakeJ
also known as the jack shaft, think i may have one in the shed, will have a look tonight
Posted: Sun Sep 08, 2013 4:43 pm
by zukmeista
I've still got one of those lying around.
Posted: Sun Sep 08, 2013 6:59 pm
by Big Jim
Awesome - I'm in Chch so if you're also here BlakeJ and keen to sell it then I'd be keen to buy it
Posted: Mon Sep 09, 2013 10:48 am
by BlakeJ
had a look and couldnt find it, i think i might have lent it to turoa to get his going, ill find out if he still needs it or not
Posted: Mon Sep 09, 2013 9:08 pm
by Big Jim
cool, is turoa in chch?
Littlepeepee, still living in Whangarei?
Hopefully it's the last piece of my puzzle!
Posted: Mon Sep 09, 2013 10:11 pm
by BlakeJ
yea he is, saw him today but forgot to ask if hes using it, will try tomorrow. Or tu's? if you see this are you still using the jackshaft? if you are no drams
Posted: Mon Sep 09, 2013 10:16 pm
by Tarmac
Thread jack but with your rear disc conv Blake - did you turn down the drums or use new plate and what thickness did you use on this? and the caliper bracket? Thanks for the answer (hopefully
Posted: Mon Sep 09, 2013 10:25 pm
by BlakeJ
havent finished it yet but going to get my flatmate to turn down the drums, easier than making plates. The brackets i got were new old stock mudbits ones, i got them for 50 buck but they sell them for like 200. BenT sells a good kit if you wanna part with the cash, i didnt.
Posted: Mon Sep 09, 2013 10:34 pm
by Tarmac
I spun down some poked drums, chopped some 10mm plate from wk, put a spare front bracket in the mill and worked out the caliper holes from the DRO. Mostly interested in the offset for the bracket as am being lazy.
Thanks anyway
Posted: Tue Sep 10, 2013 7:25 am
by BlakeJ
You can borrow my brackets if you want as i havnt put them on yet
Posted: Tue Sep 10, 2013 11:11 am
by turoa
BlakeJ wrote:yea he is, saw him today but forgot to ask if hes using it, will try tomorrow. Or tu's? if you see this are you still using the jackshaft? if you are no drams
Yep still using it, probs not much use as we chopped 2" out of it at 2am to make it fit
I do have a stock length one in my garage but its missing the flange off it
Posted: Tue Sep 10, 2013 2:27 pm
by Big Jim
ah bugger, I'm after the jack shaft and flange. Thanks though.
Anyone else?
