WJ ABS light
WJ ABS light
Hey guys, got an issue with my abs light not going out and i wondered if anyone could shed a light on this for me. I have recently renewed the front brakes and cleaned up the rear and the light was not on then and everything looked ok, not long after this the light came on, i checked for fault codes on the dash but as far as i can see these codes don't cover ABS faults, can you retrieve abs codes from the vehicle or do you need the OBD11 scanner? cheers.
Re: WJ ABS light
Can be many things... dirty or faulty sensors, clock spring, brakes etc.
Take it to a mechanic or stealership, high end scanners can read the ABS codes.
Re: WJ ABS light
yup, thought it might come to that, thought i would ask though, thanks any way
- safaripete
Re: WJ ABS light
i had to get mine scanned and came back with a faulty wheel speed sensor
managed to pick one up off ebay for 70nzd to my door
