Hey curious on how much of a lift you need to get 33s to fit, 2inch suspension and 2inch body?
Cheers Nat
95 bighorn lift
- Suza
Re: 95 bighorn lift
2" suspension lift was all mine took, but if I had to do it again I would properly go with a body lift instead as once my front was lifted I started to break things due to angles
Re: 95 bighorn lift
3inch rear and 2.5inch front suspension and 2inch body lift for mine, that was a wide body bighorn so the factory flares kept catching on the front so put normal guards off a non wide body with no flares and it was sweet.
Never broke a cv and mine got driven hard.
Re: 95 bighorn lift
I am running 33in Maxis Bighorns which only measure about 32.
2in suspension lift only and no issues on a non widebody.
If you can do it its worth doing a ball joint flip and diff drop and low profile bump stop and remove the sway bar.
Re: 95 bighorn lift
I have 33sish and they barely scrub. Haven't done a lift, yet. Finally got my 16x10s on, no worries.
