Pulled these out of my truck before I sold it.
Springs have on them DRR-30
looking at http://www.lovellsauto.com.au/docs/cat_4x4spring11.pdf
It says they are raised height for a
2/88-8/92 WD21 Wagon 2 door
Raised height is
Raises vehicle by approx 25-50mm OR
Maintains Std Height when vehicle is
Fitted with Load Bearing Accessories
When I installed them, it lifted my 4 door 1995 D21 by about 2" but I always thought my stock springs were sagged a bit...
1 Pair of Rear springs avaliable, and then just wind up the torsions in the front. I was running 31" muds with no rubbing.
Make an offer.
Chris
D21 Lifted Springs
Re: D21 Lifted Springs
$20 "preloved"
Only worth scrap value.
No offence intended.
you guys do know putting in the 2wd d21 springs has the same effect on the 4x4 d21 chassis?
gives 2" lift and articulates really well
Didn't know there was such a thing as a 2WD Terrano?
d21 isn't a terrano wd21 is. D21 is a navara
oljamesyboy wrote:d21 isn't a terrano wd21 is. D21 is a navara
tomato tomahto
another d21 terrano
ex lancer build
ex lancer build
icekayak wrote:It says they are raised height for a
I thought it was obvious Terranos were being discussed.
slidenyo wrote:you guys do know putting in the 2wd d21 springs has the same effect on the 4x4 d21 chassis?
Does the 2wd d21 springs give lift to the wd21 4x4?
I have 15x8 rims and 31x10.5x15 tyres and rubs on my guard with lil bounce, tyres do stick out 2 inches out the side of the gaurds but hopefully should tuck under the gaurds with lil bit of lift
Just to clarify a couple of things
1. WD21 Pathfinder/Terrano WAS available as a 2wd from the factory in some markets.
2. The 2wd D21 Platform (Hardbody/Navara) uses leaf springs in the rear, whereas the WD21 Platform is the same chassis except with a 5-link coil rear end.
3. Therefore its not possible to fit D21 leaf springs to a coil sprung WD21.
Thats really gonna help with his sale
why dont you tell him that that Bruce Willis was dead all along and really ruin his day
Thanks for the info tho.......
92 LWB Safari TD42
Ant wrote:slidenyo wrote:you guys do know putting in the 2wd d21 springs has the same effect on the 4x4 d21 chassis?
Thats really gonna help with his sale![]()
why dont you tell him that that Bruce Willis was dead all along and really ruin his day![]()
Actually what he is saying is technically possible and could well be true.
He is saying you can take 2wd Navara leafs and put them in a 4wd Navara for lift. This is quite possible due to different spring rates/load ratings for particular models from the factory (eg extended cab 4x4 probably had different springs to 2wd regular cab)
