Is there anyone who has installed one of the 3" FTS lift kits on to an Escudo?
I have just installed mine and have a couple of problems:
1 - There is a significant amount of positive camber on the front wheels, which I have reduced using the slotted holes in the tope of the struts together with some camber adjustment bolts, however, I still cannot get enough adjustment from these to correct it.
2 - There is noise in the rear drive line when powering on and off. (only happens when engine speed = driveshaft speed, i.e. when putting on the accelerator of letting off the accelerator). I am assuming it is caused by the increased driveshaft angle?
I have installed the 10mm spacer that came with the kit.
I have tried jacking the rear wheels off the ground and the noise gets a lot worse with the increased driveshaft angle when the suspension fully extended. I have tried loading up the rear of the Suzuki and the noise gets better as the angle reduces.
If there's anyone who can help me, would really appreciate it
I can take photos of anything if it helps.
