i have a cost effective opportunity to convert my (piece of ****) drum brakes to disks.
Essentially, BA Falcon Rear Disk Brakes are all but bolt on replacements for the stock drums.
The only thing i am not comfortable with is...
The instructions are quite detailed, and it all looks fairly straight forward, but the proviso is that you cant really use the stock Jeep rims...
OK, i do have muds, on aftermarket steelies, with the required off-set.
but i also have a set of Mags that came from my previous Terrano... these are essentially my road tires...
As professional & scientific as my measurements are, there seams to be about 5mm clearance (at the closest points between the Caliper and the wheel...
How close can the caliper be to the wheel before one should be concerned...?
I really want to lose my drums as they are really a pain after i go and sit her knee deep in mud... which is nearly every time i drive her...
Push come to shove, i can invest in a set of wheel spaces to match the offset of my steelies...
Yous thoughts..?
we assembled the brakes, and lined it up as best we could by eye sight...
The instructions i am following
http://jeep-xj.info/HowtoBArearBrakes1.htm
My Budget alignment...
