Yeah, some wheel alignment places have said " that's coopers...."
Others just want to do as many on a Saturday morning as possible.
It was getting to be a regular thing to do.
I rotated
my previous set of tires, and they all wore out
So, now I have not moved them. 3 corners are wearing evenly, and very little, the front right is causing the trouble. Lucky I have a good spare spare for when I've fixed things.
So, now I have new bushes to install, upper A and lower and compression, both sides. I was hoping to get this done on a Saturday, but after reading up on it, seems the old bushes are a siht to remove.....
I've read it's common to burn them out ? Drill them out, then burn? Is this true?
I don't have access to a torch, and I don't want to be left sunday night, car all in bits and no way to get to work....
Also, what grease?
Is different grease required for nolathane vs rubber?
My new ones look rubber. ( Black from MOOG)
Any advice?
Thanks
