Tire wear
Posted: Mon Sep 16, 2013 7:04 pm
by kiwinoz
Hi guys,
I see lots about steering issues etc, just wondering about front end tire wear. I rotate and align my tires often, but the front ones always seem to wear badly. Toe in/out is ok, but the leading edge of each grove is worn. And not uniformly around the circumference.
Is getting expensive :?
Do any of you guys have this? or maybe my whole front end is bent...
Re: Tire wear
Posted: Mon Sep 16, 2013 7:45 pm
by The WEHI
sounds like worn shocks?
Re: Tire wear
Posted: Mon Sep 16, 2013 7:57 pm
by churchill
Probably truth in that^^ Any pics?
Re: Tire wear
Posted: Mon Sep 16, 2013 8:15 pm
by kiwinoz
I have newish Rancho5000 shocks, 3 yrs. But, I have been 100,000 ks on some siht roads.
So, this isn't a common trait? That's a start.
Re: Tire wear
Posted: Mon Sep 16, 2013 8:40 pm
by lax2wlg
Possibilities:
-Idler arm bushings shot. Diagnose idler bushing by jacking up pass. wheel, wiggle and look for play around idler shaft. Solution - replace with another steering box so you never have to worry about this again.
-Upper control arm bushings shot causing unpredictable/erratic camber changes
-Tension rod (radius arm) bushings shot causing unpredictable/erratic toe behaviour
Diagnose by posting some pics.
Re: Tire wear
Posted: Mon Sep 16, 2013 10:05 pm
by kiwinoz
pics tomorrow, but is re-assuring that this isn't usual.
ps I have 2 of these, a '90 pathfinder, petrol. the one causing me tire trouble, no rust, been reliable for over 180,000 k and a '90 Terrano, which was to be the replacement, but I've found rust under the passenger seat. Damn, and just spent $1500 on the injector pump... could buy a whole new damn engine for that !
Re: Tire wear
Posted: Tue Sep 17, 2013 7:28 am
by skid
just a question about the alignment
you say its all good, but is that based on the fact you've had it done or the fact that whoever did it has said its spot on
theres a lot of shops that just set the alignment to the computer specs without thinking outside the square a little bit and adjusting it differently
just throwing it out there :wink:
Re: Tire wear
Posted: Tue Sep 17, 2013 7:37 am
by Jay
Tyre 'scalloping'.... I've been through the same thing recently. Google will show you hundreds of results about the causes etc.
Any unusual wobble's or steering wheel shakes at any speed? As The Wehi said, I'd start with shocks and go from there....
Also like skid said - alignment (from someone who can think outside the box), bushes, bearings etc etc...
Jay
Re: Tire wear
Posted: Tue Sep 17, 2013 4:50 pm
by Crash bandicoot
Top inner A arm bushes
Re: Tire wear
Posted: Wed Sep 18, 2013 12:24 pm
by lax2wlg
skid wrote:theres a lot of shops that just set the alignment to the computer specs without thinking outside the square a little bit and adjusting it differently
x2 I've noticed w/ a couple of slack alignment places, often they f** up torsion bar suspension alignment and then try to blame the customer.
ie they remove the front wheels by jacking up the control arm or frame which throws the static ride height way off. Then they align it, you drive it around for a couple of days, the torsion bars settle to their proper height, and now the castor/camber settings are way off. Then you go back and they say 'f**n Terranos are impossible to align. You have to add washers blah blah and then the bolt is too short etc. Bloody IFS. I'll need it for at least half a day.' So you say 'Nice try, but bullshit, I have aftermarket control arms which allow you to dial in camber/caster quickly and easily with minimal shim, to factory specs' Then you take your $$ back and thank him for wasting your time and thinking you are a sucker. And try to find a decent alignment place.
Re: Tire wear
Posted: Wed Sep 18, 2013 8:51 pm
by mud_slinger
shocks normally die around the 60km mark. my money is on the shocks worn.
Re: Tire wear
Posted: Thu Apr 03, 2014 12:26 pm
by kiwinoz
Yeah, some wheel alignment places have said " that's coopers...."
Others just want to do as many on a Saturday morning as possible.
It was getting to be a regular thing to do.
I rotated :? my previous set of tires, and they all wore out :twisted:
So, now I have not moved them. 3 corners are wearing evenly, and very little, the front right is causing the trouble. Lucky I have a good spare spare for when I've fixed things.
So, now I have new bushes to install, upper A and lower and compression, both sides. I was hoping to get this done on a Saturday, but after reading up on it, seems the old bushes are a siht to remove.....
I've read it's common to burn them out ? Drill them out, then burn? Is this true?
I don't have access to a torch, and I don't want to be left sunday night, car all in bits and no way to get to work....
Also, what grease?
Is different grease required for nolathane vs rubber?
My new ones look rubber. ( Black from MOOG)
Any advice?
Thanks
Re: Tire wear
Posted: Sun Apr 06, 2014 10:20 pm
by kiwinoz
Hmmmm.... must be a bit challenging....400+ views...
Guess i'll do what I usually do, charge in and see what happens.
Preparation. lube. various sized sockets. BFH. drill. biggerFH.
and a 6 pack lol
Re: Tire wear
Posted: Mon Apr 07, 2014 6:09 pm
by ChurchurDan
Tyre pressure and ride height are big contributors as well as camber and toe.
You need a decent alignment shop with a competent and experienced person doing it. If they try to say all terranos do it go somewhere else, Mine does not wear front tyres out, my last set did 7 years of daily use
Re: Tire wear
Posted: Thu Apr 17, 2014 12:24 am
by kiwinoz
Now that I have stopped rotating my tires around, I know where and what the problem is.
Have new shocks all round, recently. even swapped left right front ones.
Have new upper A, lower and compression rod bushed to install.
pics etc when I get to do it.
But for Easter, going to Wyndham, some of Gibb river road, Halls creek, Wave hill, up thru Gregory Nat Park, to Timber creek then home. Katherine. Camping dry season started.
Have a great weekend
Re: Tire wear
Posted: Thu Apr 17, 2014 11:58 pm
by DEATH_INC
The stock Terrano camber setup is wrong, it makes all the left fronts wear out the outer shoulder. Around here anyway. Post up your alignment measurements if you have them...
Rancho 5000's will last 200+k, and still work ok....well....at least mine did.
There's many things that cause 'scolloping' the answer you get will normally depend on who you talk too.
If your bushes are rubber, then don't put any grease near them, they are supposed to 'pressure bond' and rely on the rubber twisting.
If they're eurethane, then grease the inner pivot/sleeve and ends only. Never grease the outer where it fits in the arm.
The worst steering parts for wear/wrecking your alignment are;
Crossrod-it shouldn't pivot/rock at all, tho a little is ok
Idler-which also gets bent fairly easy if it isn't braced
Upper inners-you can see it if you look at them loaded, it's fairly obvious
Rear radius-tho these can get pretty bad before they affect it too much.
Re: Tire wear
Posted: Fri Apr 18, 2014 12:43 am
by lax2wlg
DEATH_INC wrote:The stock Terrano camber setup is wrong, it makes all the left fronts wear out the outer shoulder.
So you ARE still around this place! :D
Please expand on this
Re: Tire wear
Posted: Fri Apr 18, 2014 9:13 am
by ChurchurDan
Because you want the bush to rotate on the sleeve not the arm to rotate on the bush, you want the bush to move with the arm.
Re: Tire wear
Posted: Fri Apr 18, 2014 2:09 pm
by lax2wlg
Calmini/Superlift put zerk fittings on their arms.. As far as they're concerned this is to stop creaks/squeaks (works well for that) and 'significantly prolong the life of poly bushings' if lithium grease is used regularly.
Is this BS/ an oversight?
Re: Tire wear
Posted: Tue May 27, 2014 4:01 pm
by kiwinoz
Well, upper A arms bushes replaced, lower control arms seemed ok, and stuck solid anyway. TREs replaced, upper/lower ball joints both sides, not exactly sure upper A bushes are sitting right.
So off for a wheel alignment at the local. (not pub)
Explained the history and what I'd done, they said I should be rotating my tires........ I said sure. I don't think he had listened.
Anyways, attached is the print out..... and I still did not get my tires rotated, as I do not trust it is done correctly. And looks like only adjusted toe.
I have 3 near new tires and one fk"d. And a good spare from last time.
I think I'm going to have to take a couple of days off work, drive 300 Ks and stay over night to get it done properly....
Hope death_inc is about....
(when u think about it, it's a silly term rotate tires)
Re: Tire wear
Posted: Tue May 27, 2014 5:17 pm
by jeffw
kiwinoz wrote:Well, upper A arms bushes replaced, lower control arms seemed ok, and stuck solid anyway. TREs replaced, upper/lower ball joints both sides, not exactly sure upper A bushes are sitting right.
A lot of places won't do the camber on a 4wd if it has shims due to the extra time involved, if you want it done properly take it somewhere that does 4wds all the time
Re: Tire wear
Posted: Tue May 27, 2014 5:25 pm
by Crash bandicoot
and then it isn't hard to do which annoys me some what, as all ya have to do is look at the measurement, compare it to what it should be loosen off the pivot bolts add or remove shims then do the bolts back up.
Re: Tire wear
Posted: Tue May 27, 2014 5:33 pm
by lax2wlg
When you finally work out the correct number of shims for your setup, replace them with hardened washers. Shims can jump out if it takes a heavy hit off road.
Then it will chew out the threaded hole in the frame for the spindle to attach to... nightmare.
