Toyota 5L how much boost?
Posted: Mon Sep 16, 2013 7:33 pm
I now have the turbo on my truck and it is going way better!
I have a modified ct20 with a 16g compressor wheel. My boost gauge should turn up tomorrow but looking at the 5mm spacer on the waste gate I would guess that it is running about 15 psi.
Exhaust is 3 inch
have not yet touched the fuel (was smoking a bit before the turbo) and EGTs have not been over 400 (probe is a little short, new one coming with the boost gauge so might go up a little)
The motor is old 350000+km but goes well and uses no oil.
I am not too worried about buggering rings etc but don't want to put so much stress on it to risk running bearings at this stage.
When adjusting boost and fuel to a level, more fuel = more heat more boost = less heat (until turbo gets inefficient) but more power = more stress on engine.
How much is too much. Was thinking 10psi with fuel adjusted so that EGTs don't go over 550 would be a good balance.
If I am at this stage and putting more boost in makes it run colder is that good or bad? Can you run too much boost?
Thoughts?
Pete
Exhaust is 3 inch
Thoughts?
Pete
