Wheel Alignment CHCH
a80crewza
Post by a80crewza »
Going to get a wheel alignment done. Does anyone have any recommendations for a good wheel alignment place in chch. Want someone who knows what they are doing/has experience, not just following instructions, and does a good job. Thanks.
passengerpete
Re: Wheel Alignment CHCH
Post by passengerpete »
Bridgestone select 103 Blenheim road. those guys know there stuff. and don't just swing on shit till the machine goes green.
tallsam66
Post by tallsam66 »
Les Bates at Papanui Suspension in Vagues Rd.
Used him for all my hotrods & 4wd stuff over the years.
mck
Post by mck »
See Chris at Chamberlain suspension.
kiwipete
Post by kiwipete »
mck wrote:See Chris at Chamberlain suspension.
X2
Ph 0212078472
poss682
Post by poss682 »
is it for an IFS truck ?
a80crewza
Post by a80crewza »
poss682 wrote:is it for an IFS truck ?
No, an 80 series
mud_slinger
Post by mud_slinger »
i'll do it, there isn't much you can adjust on a 80 only the toe.
needs more curry
0272593533
Heath
Post by Heath »
mud_slinger wrote:i'll do it, there isn't much you can adjust on a 80 only the toe.
Unless the axle is bent...? :?
mud_slinger
well if the axle is bent then obviously it needs to be replaced or taken somewhere that can straighten it :roll:
needs more curry
0272593533
Campbell.s
Post by Campbell.s »
Go see Rob at Hannah motors in Vulcan place by far the best alignment shop in Chch, he fixes the problems other shops give up on.
Twodiffs
Post by Twodiffs »
Campbell.s wrote:Go see Rob at Hannah motors in Vulcan place by far the best alignment shop in Chch, he fixes the problems other shops give up on.
I only ever used Laycocks collision repairs who used to be on Durham Street, cheap and the best in ChCh to the point where when my old ifs Terrano had the wheels fall off due to a bad alignment by someone else - the insurance guys said take it to Laycocks. They sorted it and did any subsequent alignment to my trucks since then. Unfortunately they relocated to Sockburn and no longer do aligning...so when I asked them who in ChCh they recommend for 4wd or commercial alignments and cars etc...they gave me Hannahs motors card. Said they've got the gear and the experience. Knowing Laycocks reputation that was good enough for me.
mud_slinger
he taught me alot when i first started out. good fella and knows his stuff
needs more curry
0272593533
a80crewza
Post by a80crewza »
Cheers fellas. Have booked it in for an alignment. Thanks for the help. :)
Return to “Tool Shed”
