help me!!!!!!! i confused
brakes-shocks-lockers-etc
mud_slinger
Post by mud_slinger »
i dont no wat the problem is!!!!!
went out 4wd llast sunday arvo, got into a mud hole. while getting pulled out i hooked reverse and i lost all drive to my wheels. got towed home by kaney. couple times ive started it up and tried to drive it but ive had nothin. in 4 low i get a tiny bit of drive and i mean like 1 meter an hour. so i thought clutch maybe issue. dropped it out today and clutch is fine plenty of meat an no damage at all. wat else could it be???????? gearbox as far as i no is fine like it neva made a crunch or any other noises.someone help me. i cant explain.
cheers :x
DaveM
Post by DaveM »
Are you sure the clutch is engaging?
mud_slinger
i could see the slave cylinder push the fork in
DaveM
Post by DaveM »
If your getting any drive at all, I would have thought it would have to be the clutch :?
mud_slinger
i could move it a meter or so in 4 low wit someone givin me a push. that all i the drive i had. clutch is fine. im stumped. its a mu
klompy
Post by klompy »
Make sure mud,small stones and sticks hav'nt flung out in your pressure plate stopping release fingers from returning to clamping position.Had this happen to me once. :oops:
mud_slinger
there is a little bit of mud an shit but not enough i dont think to be the prob
DaveM
Post by DaveM »
Isuzu's don't come with dual mass flywheels do they?
mud_slinger
now ya lost me. i have no idea wat ya mean
red-devil
Post by red-devil »
can you remove the fork and check thats it's not bent and that the springs are workig on it to help close the the plate up against the flywheel.
DaveM
Post by DaveM »
Toyota surfs had 2 piece flywheels, with rubber connecting the 2 together (I think). This was to stop vibrations from the diesel motors, but the rubber between would strip, allowing one side of the flywheel to drive but, but the 2nd wouldn't.
I'd keep checking around the clutch though.
mud_slinger
i havent checked that yet.will do tho
mud_slinger
mine jus a one piecer
kaney
Post by kaney »
still no go aye. that sux. it did loose drive in the first hole and then once he was out he was driving fine and he didnt completely loose drive until in a deeper hole further from home (murphys law aye).
mud_slinger
still no go mate. not sure wat my next move is really
WACKO
Pyro
Post by WACKO »
so when you got it home, you were in 2h, you put it in first and let the clutch out, and i did nothing? no drop in revs, no movement, just sat there as if nothing had hppened?
did the clutch pedal feel any differant? did it still have clutch feel to it?
mud_slinger
yeah mate not a thing. tried evey gear. clutch felt normal.
WACKO
Pyro
Post by WACKO »
and if you reved it it was like it was in neutral?
i reckon you got some crap in your clutch somwhere.
id give all the clutch parts a huge cleanout then put them back in and try it again.
but im no mechanic so i could be wrong.
mud_slinger
already pulled them out. gettin a bit of dirt from round the fingers in prssure plate but apart from that clutch and al seems pretty clean
Moriarty
Post by Moriarty »
Ok, wen the clutch out, did you drop engine or box out to check?
if box, does drive go thru box? put in gear, try to turn input shaft.
does OUTPUT shaft turn?
if Engine out, do same thing, is resistance to turning forces?
can you turn drive shafts?
follow whole drive train thru, with all wheels up in air. then you will be able to isolate prob easier.
Aaron
Post by Aaron »
Take the clutch plate and the cover to clutch systems on Hazeldeen rd and they will test it for you, it sounds like a broken diaphragm spring in the clutch cover. :)
Toyota 70 series cruiser, 13bt
Phone 029 454 8533
mud_slinger
thanks aaron i will do that.how much is it? or is it free?wen i turn input shaft on gear box the output shaft turns. tried holding output shaft while turnin input and nothin broken in gearbox.
niblik
Post by niblik »
Aaron wrote: clutch systems on Hazeldeen rd
got a good crew in there. helped me out heaps with my 40's clutch plate.. real helpful fellow..
mud_slinger
sweet thats wat i want to hear. cheers guys. will keep you posted as to wat the issue is
wopass
Post by wopass »
Aaron wrote:Take the clutch plate and the cover to clutch systems on Hazeldeen rd and they will test it for you, it sounds like a broken diaphragm spring in the clutch cover. :)
what he said, cracked diapghram in the pressure plate
