WTD: FJ40 early 4 speed xfer case
williamhamilton
Post by williamhamilton »
Hi guys, looking to see if anyone has a decent xfer case for a 1975 FJ40 good condition with a good price :) Local would be great
W
mudlva
Re: WTD: FJ40 early 4 speed xfer case
Post by mudlva »
For that age you will be looking for a single peice trans box at a guess
williamhamilton
Yup that be correct, should have stated that :) Was getting a bit noisy so if no good one flating around new bearings etc will be purchased.
W
williamhamilton
Bump - idler gear and shaft I can make do with if in decent condition - mine looks like the hardening has gone (not sure if these are the same between versions or not) 27 & 41 teeth pin size 25.3
W
