They work really well.
Got a V8 4X4? A suggestion...
I suggest, for shits and giggles, installing a set of these from badlanzHPE.com .
Re: Got a V8 4X4? A suggestion...
neatest exhaust i have seen was chrome stacks up behind the cab of a longreach falcon ute in cambridge.
was thinking i'll side dump the exhaust on the mistral if i ever get around to chopping the back off it. lol
What's the legality with the dumps emptying under the cabin? I assume as long as the std pipes are used for everything other than "track work" then they are fine?
Heath wrote:What's the legality with the dumps emptying under the cabin?
Dumps not allowed for on NZ streets, would be a race vehicle only thing.
VIRM 11-1-5 wrote:5. The exhaust system is so constructed that emitted heat or fumes are likely to harm vehicle occupants, eg the exhaust gases are not directed away from the perimeter of the vehicle’s passenger compartment
Those valves in video not legal for nz roads either,
VIRM 11-1-4 wrote:The exhaust system is so constructed or modified that its operation or effectiveness can be readily interfered with
As cool as they are, it could get expensive have to change back to original for wofs... Dumb really because it would give the driver the ability to drop down the noise in residential areas. Guess they gotta make the rules because of the few who would only make it quiet around the authorities...
Have mates with them fitted. There's no problem with WOF's.
But there's always someone who knows everything.
juz wrote::lol:pot kettle black pete....
What do you wanna know Juz?
Had to laugh earlier when the partner wanted to see them work in the garage. The look on her face. Gold.
yep had them on the hilux, 3 inch one from each turbo charger on the Rb30/26 combo.
one muffler for each pipe and straight out the side in front of the left rear wheel.
never had an issue at wof time.
Mate runs them on his mustang. Never been flagged at wofs. vtnz boys just thought they were cool
petefj40 wrote:Have mates with them fitted. There's no problem with WOF's.
Not sure quite what you mean there?
But just goes to show what a crock of shit wofs are then aye?
http://vehicleinspection.nzta.govt.nz/v ... ust-system
under reasons for rejection
4. The exhaust system is so constructed or modified that its operation or effectiveness can be readily interfered with, eg the driver is able to interfere with the exhaust system by operating a manual switch, or the exhaust is fitted with a flame thrower kit.
cool idea. not technically legal. pretty lol that vtnz guys fizz up about them, they should really be failing a wof on them.
typical 'v8/harley' crowds getting away with whatever they want
I guess a backing plate and some butterfly nuts to cover it until at the track might suffice to keep the fun police happy. Be a bitch to get too with a low vehicle - although I guess they would only have to be there for the WoF etc.
Was considering something similar for my rod project, but with gasser style pipes down behind the wheels and a dump pipe venting outwards when opened but a full normal exhaust when its closed. Might just revisit that idea if the rules wont allow it.
reminds me of a comment a commentator at the v8 super cars once made. about how all the castrol/perkins built commodores ran full length exhausts compared to all the rest.
Heath wrote:I guess a backing plate and some butterfly nuts to cover it until at the track might suffice to keep the fun police happy.
That's the one. It's easy enough to take the butterflys off (they un-bolt and wiring unplug) and replace them with plates if there's any issues.
slide wrote:petefj40 wrote:Have mates with them fitted. There's no problem with WOF's.
I meant that a few others I know have a similar setup on their street legal rides and have no issues with WOF's. But clearly as Cameron stated, if the system can be modified with a switch they fail a WOF. Try and find mine.
But you're right Slide, the rules are crap.
