If you get water in air intake and motor stops (dont try turn over), simple fix in bush. take apart air intake and filterbox , all the way back to manifold empty out the water spray with CRC to disperse water, wipe clean. by loosening off glow (untill just sitting on the thread) plugs and turning engine over 'hydrolicing' will push water out of chamber via glowpulgs. just keep turning over untill all mist is gone may take 10mins - fun to watch
. after this connect everything the way it was and turn over be careful and listen for the sound of motor getting 'tight' if so immediately stop and repeat the procedure (takes awhile). eventually she should start up.
-Just a helpful tip if you know the basics not detailed enough to depend on . worked on discovery
