g13A rebuild
g13A rebuild
anyone know where I can send my G13a engine to be rebuilt?
Re: g13A rebuild
Where are you located? I'm sure someone will be able to give some guidance
if they know a rough location and maybe the condition of the motor to be rebuilt.
To add your location to your profile click "Home" on the top left of the page then on the Right click "Private messages" then on "Profile"
Welcome to the forum.
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
Re: g13A rebuild
cheers mate its just started knocking in the bottom end so id say needs a cam grind and new shells
Re: g13A rebuild
I wouldn't bother, just do a coversion to the 1600 out of the vitara.
Re: g13A rebuild
Na I want to keep it as it is dont want to have get a cert for it
Re: g13A rebuild
Just get an 8-Valve 1600, looks exactly the same. The 1300 is not worth spending any money on.
Re: g13A rebuild
zukmeista wrote:Just get an 8-Valve 1600, looks exactly the same. The 1300 is not worth spending any money on.
While that might fool the WOF man you probably won't be able to get it past the insurance company, especially if the accident involves hitting an expensive vehicle.
Re: g13A rebuild
ha my injected 1600 gets past the wof man, bonnet scoop to hide hole in bonnet and all.
Re: g13A rebuild
im with nzlux..... I only use it to run to work in so more power isn't what im after im sure its cheaper to rebuild the little 1300 than to buy a 1600 let alone get it into the truck
Re: g13A rebuild
Don't think so, my 1600 conversion costs were $500 for motor, $50 for new top end gasket kit, $150 new timing belt kit (you will need those things for a rebuild anyway) and $200 for the adaptor kit. Ppffftt if you're driving a suzuki you probably can't afford insurance anyway.
Re: g13A rebuild
will a g13b twin cam set up bolt up to my 413 with out any mods ?
Re: g13A rebuild
cheers zukmeista looks good
