TD27T charging issues
For all Nissan related topics
marrco
Post by marrco »
I have a 1990 TD27T and over the last few days the battery has slowly lost it's charge, the battery is only about a year old and it charges up fine on a mains charger, the alternator was replaced with a new one about 6-7 years ago.
The issue I'm having is the battery light in the dash does not come on when the ignition is turned on and stays off when running, I've checked the bulb and it's all good, I've checked the voltage across the battery when running and when not and the voltage stays the same which suggests the alternator is not charging but at the same time the battery light is off.
Done a bit of a search on here but can't find anything useful, I'll be taking the alternator to a sparky tomorrow to get checked, also checked all fuses etc but everything is fine, this one has me a bit stumped, can anyone here shead any light on this, if so it would be much appreciated.
Cheers.
BlakeNZ
Re: TD27T charging issues
Post by BlakeNZ »
once i had an issue similar to this with a TD27T and it turned out the plug (rectangle from memory) at the back was not quite pushed "home" properly. I know it's a long shot, but just check.
Crash bandicoot
Post by Crash bandicoot »
failing the plug on the back of the alternator get a multi meter and put accross the battery terminals whilst the engine is running the gentley tap the alternator with a hammer(gently) been 6-7 years it may have stuck brushes.
sibainmud
Post by sibainmud »
Most likely the regulator is "smoked" if the light isn't working with the engine not running and the key on. Often the cause is the rectifying diodes have shorted stressing the regulator. Search around for a new one as the shaft might be worn where the oil seal is from the vacuum pump.
marrco
Post by marrco »
sibainmud wrote:Most likely the regulator is "smoked" if the light isn't working with the engine not running and the key on. Often the cause is the rectifying diodes have shorted stressing the regulator. Search around for a new one as the shaft might be worn where the oil seal is from the vacuum pump.
New alternator now in and running as it should.
Cheers for everyones advice :D .
