Hey guys
Got panhard rod sorted, failed WOF on front left drag link ball joint. Apparently there is too much play in it now. Tried packing it with grease but no luck.
Had replacement drag link priced by my local Nissan supplier at $400!
So I need suggestions on weather i should buy a second hand one and hope for the best or try aftermarket. IF anyone has a good condition second hand one, flick me a private message.
WTD: GQ Safari drag link
- Gran_Safari
- Driver/Navigator
- jonossiksilvia
Re: WTD: GQ Safari drag link
wouldnt it be better to get new end joint for it? or is that not possible with safaris? i just got 4 joints for my front end all brand new under $200
- Gran_Safari
- Driver/Navigator
drag link is one piece from what i can tell, tie rod has removable ends.
Patrol GQ Adjustable Drag Link Heavy Duty - Pin to Pin Steering Damper
http://www.4wdbits.co.nz/ProductDetails.aspx?productID=1313 $286
I saw BNT could do a heavy duty one for less than that. i think i was told just under $200 but can't remember.
