I got some 1 ton chain blocks, with a minimum of 8 meter chain drop, including the endless chain, easy to shorten with grinder
Oz Bloc
FEATURES
• Lightweight robust construction
• Super strength alloy loadchain
• Fully machined liftwheel
• Minimum headroom
• Minimum effort to raise maximum load
• Cast steel safety latches
• Lower hook complete with thrust race
• Fully enclosed gear train
• Weather protected automatic Weston brake with unique Twin Pawls
• Galvanised handchain as standard
• Durable baked enamel paint protection
• Stainless Steel labels
chain catch bag included
$80 per hoist + frieght, they weigh 28kgs!!!
also have access to beam runners
Chips in paint work from putting in and out of storage
Cost $$189 new
Fits beams from 64 - 203 mm
A strongly constructed, fully adjustable trolley designed to fit universal beams and columns
•All girder trolleys are manufactured to comply with AS1418.2.
•Fully adjustable to suit various beam widths.
•High-grade, fully sealed bearings for maintenance free extended life.
•Anti-drop plates as standard for improved safety and compliance.
Net Weight 16.8 kg
$100 each.
Pacific Hoist Girder Clamp
As new condition
Cost $120 new
Pacific Girder Clamps are used to safely suspend loads of many descriptions from girders (I-beams). Manual, Electric and Air hoist installations are examples of their wide capability of usage.
Features:
• All Pacific girder clamps are manufactured to comply with AS4991.
• Quick and easy to install and reposition makes them ideal for maintenance tasks.
• Jaws clamp over girder flanges.
Also suitable for lifting I-beams.
• Can be used at up to 45 degree angle with a 50% reduction in capacity.
Specifications
MODEL PGC310
Rated Capacity 1000 kg
Beam width range 80 - 245 mm
Net Weight 5.9 kg
$80 each
PM for more info or of you want one
Pedro
