Elf oil
Big
Elf oil
Post by Big »
Hi everyone. .just to confirm that Elf do in fact sell the SP680 worm gear oil in 5ltr packs as there was a discussion about how they didn't. .
Just giving you the heads up.
Ring Ross 0800353645 and he'll sort you out.
Also regarding the landcruisers transfer box.. do NOT use a Gl5 rated gear oil in your transfer box as it has properties that eat the brass off the thrust washers..must use a GL4 gear oil..
That's it..tata
If a mod feels that it should go somewhere else.. then by all means.. move it
