Its mounted in the dash below the stereo, there are two relays there, one for the electric aerial and the other is 4WD. It sends out the positive signal to the dash lights.
Yep true it is slightly lower but do you know where the LR disco V8 engine ECU is. Yeah that's right the arguable king of 4WD's brands locates this most vital piece of equipment probably the lowest possible point inside the cabin. Under the front seat. Ive never understood why they don't locate them inside the dashboard area where ironically a good number of regular car makers position them.
