dash lights miti
Posted: Wed Oct 23, 2013 3:50 pm
by aceospadez
hi peoples
on my 1993 miti pajero swb the when i put into 4wd the lights on dash dont light up checked bulbs all ok what else do i need to look for
thanks sam
Re: dash lights miti
Posted: Wed Oct 23, 2013 6:18 pm
by JohnySWB
This link may help you with your problem.
Click the link below.
http://4wd.blogeasy.com/article.view.ru ... eID=318776Cheers.
Posted: Wed Oct 23, 2013 6:29 pm
by aceospadez
Thanks man will try that tommoro
Posted: Wed Oct 23, 2013 11:38 pm
by aceospadez
The ecu that controls 4x4 system died probably when I drowned it
Posted: Thu Oct 24, 2013 6:48 pm
by aceospadez
yup 4x4 ecu stuffed got one today 80bucks job done all back on line thanks for that page dude
Posted: Thu Oct 24, 2013 7:56 pm
by JohnySWB
Drowned ecu, ok that was easy then I guess.
Where is 4wd ecu then. Ive never had to play with that bit before.
Wheres it located and whats involved.
Thanks in advance, cheers.
Posted: Fri Oct 25, 2013 8:43 pm
by NJV6
Its mounted in the dash below the stereo, there are two relays there, one for the electric aerial and the other is 4WD. It sends out the positive signal to the dash lights.
Posted: Sat Oct 26, 2013 9:20 am
by JohnySWB
Thanks NV. That info may well come in handy one day.
A little prone where it is. I suppose you can water proof them.
Cheers.
Posted: Sat Oct 26, 2013 6:01 pm
by NJV6
The ECU for the engine is lower! Think the 4WD would be the least of ya worries!!
Posted: Sun Oct 27, 2013 6:45 am
by JohnySWB
Yep true it is slightly lower but do you know where the LR disco V8 engine ECU is.
Yeah that's right the arguable king of 4WD's brands locates this most vital piece of
equipment probably the lowest possible point inside the cabin.
Under the front seat.
Ive never understood why they don't locate them inside the dashboard area where ironically a good number of regular car makers position them.
Don't figure.
Posted: Sun Oct 27, 2013 8:20 am
by aceospadez
Ecu on pajero left hand kick panel witch now in water proof plastic box on glove box
