I brought a surf last week, its been basterdised a wee bit by the previous owners. First up the vsvs for 4wd are gone, but I have connected vacuum to the front diff and the drive shaft became solid (couldn't turn it with wheels on the ground) and when I switched it back it freed up.
So I think that part of its fine, My question is what does the transfer case need to send power forward.
Signal from the button on shifter and vacuum? or does it need signal from the front diff aswell?
yn130 transfer case
Re: yn130 transfer case
Or does anyone know where i can find the info?
- jonossiksilvia
these may help get you started
http://www.offroadexpress.co.nz/Forums/ ... 22&t=38107
http://www.offroadexpress.co.nz/Forums/ ... 22&t=35133
http://www.offroadexpress.co.nz/Forums/ ... 22&t=34915
http://www.offroadexpress.co.nz/search/ ... 6t%3D34915
