ct 26 turbo
firestonecruiser
ct 26 turbo
Post by firestonecruiser »
was thinking of upgrading turbo on my 80 series when i do 3 inch exhaust. what is a good replacement turbo to use cheaper the better or should i get mine rebuilt. it still goes fine but truck has done 300 000 plus ks. truck tows a 14 foot caravan about 5 times a year.
cheers jono
The WEHI
Re: ct 26 turbo
Post by The WEHI »
td05 16g cheap to rebuild and upgrade and are good turbos
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
turoa
Pyro Junior
Re: ct 26 turbo
Post by turoa »
To be honest you're much better keeping the ct26 and get it rebuilt with a larger compressor wheel if you want a bit more oomph out of it. I've put an aftermarket turbo on mine and although it goes pretty damn well, its not really worth the effort. I originally did it as at the time it was cheaper than fixing mine or purchasing another turbo (all of the internals were rooted).
Have a search through the forum, a few people have suggested places to get them rebuilt. If you want to spend oodles of money, google gturbo.
mud_slinger
Re: ct 26 turbo
Post by mud_slinger »
jarod at turbocare knows his stuff he did my one for me
needs more curry
0272593533
firestonecruiser
Re: ct 26 turbo
cheers guys. better start getting the coin together as i may aswell do turbo, exhaust and injectors at the same time
bushwacker
Re: ct 26 turbo
Post by bushwacker »
i got mine rebuilt on my 80 with a bigger compressa wheel put in it and it spools up 200rpm early that it use to, takes off better and pulls loads better up hills, i highly recommend it.
philipw
Re: ct 26 turbo
Post by philipw »
bushwacker wrote:i got mine rebuilt on my 80 with a bigger compressa wheel put in it and it spools up 200rpm early that it use to, takes off better and pulls loads better up hills, i highly recommend it.
What size is the compressa mate?
bushwacker
Re: ct 26 turbo
craig at http://www.turbodoc.co.nz did the job
this is a pic of old wheel and the new one
bushwacker
Re: ct 26 turbo
s the cost
here is a quote to strip, clean,machine housing to fit bigger compressor wheel,balance turbine assembly and recondition unit (new bearings,seals orings etc)
recondition kit (bearings,seals etc) $220
machine compressor housing and c.h.r.a $230
new high flow compressor wheel $155
balance turbine assy $75
p&p,cleaning/sundries $25
labour (2.5hours) $162.50
total $867.50
