Ford Courier Body Lift
Anyone done a 50mm bodylift on a 2004 Ford Courier? If so was what had to be adjusted to make it drive-able, Eg Steering, Radiator etc, any info would be very much appreciated. Cheers
Re: Ford Courier Body Lift
If its airbag it cant be certed as you will have to remove the airbags and they have to be 14 years old minimum to get no airbag cert !
I have been in a 2006 one that didn't have airbags so would assume no airbags.
Possible i have two customer with them one of which is waiting till january so he can cert it (its a 2000 model )
Mine has no airbags so wont be an issue.
