Just after some advice,had the truck up Waipara Gorge on Monday and found 1/2 way thru the trip the clutch pedal felt lumpy to push like it had a cable that was dry.
The clutch still worked fine but being hydrulic not sure why this happened,next day not lumpy back to normal.
Q.As water obviously got in then dried out, are there any tricks to this issue anyone has come across
