Removal of stablisier disconnector?
Posted: Sun Oct 27, 2013 8:33 am
by MrBeef
Hey,
My stabi disconnect is quite flogged out on the ball joint where it connects the bar itself. Am wondering if anyone has removed the whole system before and just used standard linkage (or adjustables for lift kits) obviously there'll be issues regarding mounting the replacement linkage.
Or am I just pissing in the wind better off to get replacement unit? I'd just leave the sway bar off all the time but for warrants and all that jazz, leaving it on and having poked ball joints theyll prob pick up on that
Re: Removal of stablisier disconnector?
Posted: Sun Oct 27, 2013 9:34 am
by crazyclark31
easy peasy to change. hardest part is pulling all the disconnect stuff out. just get some correct length links(to suit whatever lift you have) and put them in.
Posted: Sun Oct 27, 2013 12:26 pm
by MrBeef
Oh yes? And the bracket the disconnector sits on is suitable for linkages to mount to??
Posted: Sat Nov 09, 2013 5:49 am
by MrBeef
Has anyone done this? whats involved with setting up standard linkages?
Posted: Sat Nov 09, 2013 8:46 am
by coxsy
use the four bolt hole to bits of steel plate drilled the same plus hole fore the rubbers to sit nice for new link
