Need to replace clutch in the terrano.
W21
Is there an ideal upgrade for more clamp pressure or a standard 1 ok?
Will be doing mild towing, and increasing hp in the future.
Jared
new terrano clutch
Re: new terrano clutch
Check out the Exedy Clutch options of for clutches. They are proving very good and popular in Aussie and now also here. Based in Glenfield, Auckland.
Also if doing the clutch plate make sure you replace the pressure plate as well.
