LJ71 prado parts F/S
I have a LJ71 prado parting out.
PM me offers for parts, or ask here.
Engine, transmission and front axle gone.
(still have 2.4 EFI fuel pump&ecu)
Has factory e-locker rear diff lock (4.88:1) (works but motor sad).
Am willing to store parts until suitable freight (ORE courier etc) sorted.
Nathan
Nathan
Re: LJ71 prado parts F/S
hey dude
have you still fot that centre consol around the auto shifter?? also wing mirrors & the heater shut off valve in the engine bay, the stuff i looked at ages ago
I made another trans from a few parts ones i had on the cheap.
Should be over for the 4wd club anniversary 8-9 nov
Cheers Leigh
Cheers Leigh
Hey Leigh
Yep, got heater shut off valve. Which part of consol were you after? ( I forget now
Maybe I'll Pm you a photo tomorrow and get you to circle bits you wanting?
Mirrors I've still got at this stage
Nath
Nath
the main part around the shifter and it houses the ect and power buttons
Yep thats no problem. I'll get bits out so you can get weekend 9-10th when you're over
Hi Mate, have you got a passenger door? Doesn't have to be perfect, just moderately straight & non-rusty. If so I'll check out the freight cost.
Clint
Clint
UZJ71 Landcruiser
KTM 640
KTM 640
Looking for a Electric Window Switch off the Drivers side door ( # 84820-87010 ) would it be the same as a 1993 Prado ?.
I'll check numbers on it for you
Edit- found number 74231-60050 on the plastic trim part, only number I see on switch part is 289-5p21
Where did you get the "84820-87010" from?
Maybe I got a missing sticker?
Clint wrote:Hi Mate, have you got a passenger door? Doesn't have to be perfect, just moderately straight & non-rusty. If so I'll check out the freight cost.
Clint
Passenger door is dead straight and no rust.
Yea, check freight cost and make an offer
From Toyodiy.com.
Looks like its the same part. you can email me oldblue@clear.net.nz
redz driver
looking for front brake calipers thanks
Real men drive swb leaf spring trucks
redz driver wrote:looking for front brake calipers thanks
Can't help ya this time sorry
- kzn130smurf
- Winch master
Hey, is the rear diff a 8 inch?
Was it auto? If so could you tell me the trans code off the tags
hay mate just looked at the trademe pics do u still have the rims ?
Yep, was auto. Trans code a343f
And yep 8" diff G144.
And yep, have still got rims from trademe pic
Hey do you have that Ect i will be over next weekend and how muchy. Cheers Leigh
Yep, got that waiting for ya. PM sent
